(with zabbix beta 1.3.4)
I configured one scenario with one step : one pointing to http://www.url1.com for example.
The response code of the first step is 200 and it status OK.
Then, I tried to use the REQUIRED field in step configuration. I typed a crazy string in order to force zabbix to not find it inside the html.
The response code of the first step is always 200.
I would like have error if zabbix don't find the text required.
