in my simple mind I thought, that all checks (items) I can request from
remote (passive) should also be possible locally by the agent (active).
However, when I change, e.g., the check for disk free on drive e: (Windows)
from "agent" to "agent (active)" no data are send.
Is this expected or is it a bug in 1.3.5 (beta) ?
Does it correspond to the problem with "zabbix_agentd -t arg"
on Windows (1.3.5) which is described in this thread
Of course, this is not valid the other way around, i.e. some active checks
can not be done remote (like logfile watching).
In order to avoid overloading our server, we need to do as much as local
checks as possible.
Regards,
Norbert.
checks as possible.
Regards,
Norbert.
