FreeBSD 6.1 - Zabbix (1.3.5) agent
  • NOB
    • Mar 2007
    • 469
    I think this problem is not really related to the version of Zabbix in use.
    That's why I post it here
    The zabbix_agentd can not be run as user "root".
    This is fine for me.
    However, this poses problems because the /proc pseudo-filesystem
    is used for process monitoring and a normal user (zabbix) can not
    access any real data, except it's own processes (e.g. zabbix_agentd)
    or the total number of processes.
    An "ls" of /proc is, of course, possible.
    But requests like proc.num[sshd] returns 0, although
    one process is running. The same applies to the syslogd process, etc.
    Is this a known problem ?
    If so, I'll try to change the agent to use sysctl, instead.
    First experiments show, that sysctl returns useful data, even for a
    non-root user incl. the user of a running process, the command-line, etc.
    If not, please tell me how to run the zabbix_agentd on FreeBSD !
    Regards,
    Norbert.
