Unable to compile zabbix 1.3.6
  • predatorz
    • Mar 2007
    • 109
    Hi, i think i have installed all the packages for zabbix but when i tried to compile it by running ./configure, it fails.. What is the problem?
    i installed mysql-server, mysql-devel, net-snmp, net-snmp-devel, ikesemel, php, php-mysql, php-gd, fping, gd-devel, gcc.
    i tried yum install mysqlclient but it say nothing to do.
    Running on FC4.
    checking for socket... yes
    checking for strtod... yes
    checking for snprintf... yes
    checking for vasprintf... yes
    checking for asprintf... yes
    checking for vsnprintf... yes
    checking for hstrerror... yes
    checking for atoll... yes
    checking for getopt_long... yes
    checking for mysql_config... /usr/bin/mysql_config
    checking for main in -lmysqlclient ... no
    configure: error: Not found mysqlclient library
  • predatorz
    • Mar 2007
    • 109
    Any hints ?
    • predatorz
      • Mar 2007
      • 109
      Anyone Can Help? Thanks in advance.
      • SierraX
        • 21
        mysql not in a standard path?
        • BusteR81
          • Apr 2007
          • 150
          wrong default path
          zabbix finding in /usr/lib
          while mysql in /usr/lib/mysql
          what u can do is do a cp (copy) command
          or u can change the path in configure.in OR configure....
          i did a cp command coz i duuno how to edit paths in configure files.
