Zabbix Agent 1.1.7 Installation
  • asyadiqin
    • May 2007
    I've download the source from sourceforge and followed the documentation for zabbix agent installation.
    However, in the manual, step 4, the intructions were as follows :-
    Step 4
    Build agent
    shell> make
    Copy created binaries from bin/ to /opt/zabbix/bin or any other directory.
    Other common directories are /usr/local/bin or /usr/local/zabbix/bin.
    Problem is I cannot find the binaries in the bin/ folder except for 2 files, which is as follows :-
    [root@fc5-i3 bin]# pwd
    /home/zabbix/zabbix-1.1.7/bin
    [root@fc5-i3 bin]# ls -la
    total 288
    drwxr-xr-x  2 1002 1002   4096 Mar 30 17:38 .
    drwxr-xr-x 10 1002 1002   4096 May  8 13:13 ..
    -rwxr-xr-x  1 1002 1002 118784 Mar 30 17:38 ZabbixW32.exe
    -rwxr-xr-x  1 1002 1002 159744 Mar 30 17:38 ZabbixW64.exe
    I am installing the zabbix agent on server running Fedora Core 5. FYI, the zabbix server is already installed on another machine and everything is fine on that server.
    Can someone please provide me with a detailed instructions as to how to install and configure the zabbix agent on my server. Please provide instruction for using zabbix_agentd. Thanks.
  • SierraX
    • 21
    I seem you search for src/zabbix_agent/zabbix_agentd
    Copy it to the right place, take also a look to misc/init.d/redhat/8.0/zabbix_agentd for the Init script.
    I am a noob user too and take a short look on a OpenBSD 4.1 OS
    too look for a file use find
    copy to a place you want it. create a user named zabbix and start the agentd with the needed parameters.
