hello everybody
first of very compliments for this fantastic product.
I have a problem with the agent (v 1.1.6) on a system aix 4.3.
I have installed it, but when it start report this error:
0509-130 Symbol resolution failed for zabbix_agentd because:
0509-136 Symbol ___bzero (number 1) is not exported from
dependent module /usr/lib/libc.a(shr.o).
0509-136 Symbol ___memmove (number 2) is not exported from
0509-136 Symbol ___fill (number 3) is not exported from
0509-192 Examine .loader section symbols with the
'dump -Tv' command.
the version of aix 4.3 are supported?
if it's not so, how i can monitoring the system aix?
with SNMP it is necessary to install the agent on the system aix?
thanks for the help
'dump -Tv' command.
thanks for the help
