is HOSTNAME Variable possible?
  • dpsantos
    • Mar 2005
    • 60
    is HOSTNAME Variable possible in the triggers description?
    If yes, can anyone tell me how?
    Duarte Santos
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I believe the macro {HOSTNAME} is already supported!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Wolfgang
      • Apr 2005
      • 116
      {HOSTNAME} is supported in V1.1A7 at least for Trigger Describtion. I haven't checke for wether it can be used somewhere else.
      http://www.intellitrend.de
      Specialised in monitoring large environments and Zabbix API programming.
      • rxm8028
        • Apr 2005
        • 45
        Variable in Trigger Name
        I am attempting to use the {HOSTNAME} variable in a trigger description, but when I view the trigger on the OverView screen, it just says '{HOSTNAME}', intead of substituting the actual name of the host. Is there some subtle syntax I am overlooking?
        PS - I am running Zabbix 1.1A9.
        Thanks,
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          There're could be many hosts per one trigger in the Overview Screen. It makes no sense to replace {HOSTNAME} by actual host name. Why?
          Alexei Vladishev
          My Twitter
          • davewinter
            • Jun 2006
            HOSTNAME in Trigger Overview
            I get the same thing! It would be much easier to logically break items up if this worked.
            Thanks,
            • davewinter
              • Jun 2006
              Alexi,
              I see what you mean,can we at least remove the {HOSTNAME} from showing up in the Overview?
