Zabbix packetage what?
  • mika2006
    • May 2007
    • 15
    Hello i m looking fo r all packetage requierd to install zabbix:
    for the moment i instlal this but i need other please help:
    up2date -i httpd php php-mysql php-snmp mysql mysql-server net-snmp net-snmp-utils net-snmp-libs
    because i have tis problem when i compile:
    [root@localhost zabbix-1.1.7]# ./configure --enable-server -with-mysql --with-net-snmp --with-jabber -with-libcurl
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    configure: Configuring
    checking whether make sets $(MAKE)... (cached) yes
    checking build system type... i686-pc-linux-gnu
    checking host system type... i686-pc-linux-gnu
    checking for gcc... no
    checking for cc... no
    checking for cl... no
    configure: error: no acceptable C compiler found in $PATH
    See `config.log' for more details.
  • predatorz
    • Mar 2007
    • 109
    gcc package
    • mika2006
      • May 2007
      • 15
      thnaks i find the command
      #up2date -i gcc
