zbxCallPostScripts error in browser
  • finite
    • May 2007
    I'm doing a new install on a linux box (2.4.20 kernel - no option to upgrade at this time). I've got everything installed and everything behind the scenes seems to be working except for the initial setup.php. The first time I connect to our Zabbix box I get the initial Introduction screen. I click on "Next" to go to the license agreement and all I get is a blank screen. When I look at the error console I see "zbxCallPostScripts is not defined" which refers to this line in setup.php:
    <body onLoad="zbxCallPostScripts();">
    I've searched the web, the Zabbix wiki, and the forum here but there is no mention of zbxCallPostScripts anywhere that I can find. Anyone have any ideas what I'm doing wrong?
  • predatorz
    • Mar 2007
    • 109
    after compiling zabbix 1.3.7, and try to configure the frontend, also keep stuck at setup.php, with IE throwing a script error and firefox just show a blank page.
    Any solutions?
    • finite
      • May 2007
      I think I figured out what the problem was, or at least we found a dependency problem that we didn't verify before we did the installation - turns out that reading the prerequisite list is helpful sometimes We have php 4.1.3 installed but the version of Zabbix we installed requires at least 4.3. I'm going to update that tomorrow and we'll see if that fixes the problem.
      • cbidwell
        • Aug 2006
        • 127
        Have you tried clearing your cache? I had the same problem and after clearing my cache, the problem was resolved and I got my login screen.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          We cannot reproduce this problem. I'm removing it from our TODO list.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • kng
            • May 2010
            I am getting this same error using the 1.8.2 Virtual Machine from your site when trying to import any template.
            I increased the memory_limit to 256MB. Still no luck.
            Ideas? Thanks!
