Admin Login
  • mkaser
    • Sep 2006
    Admin Login
    Fresh install on debian4. Can't login with IE7 or IE6 with user admin. Firefox works fine. Can anyone assist?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Perhaps you have cookies disabled under IE?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • VeryNewbie
      • Feb 2007
      • 40
      I have the same problem... I tried in Mozilla and IE6 but in both it doesn't work. Does anybody know how to fix it? what do I have to do? First I though it was a problem with the linkage, but it seems to be something else...
      TIA
      • VeryNewbie
        • Feb 2007
        • 40
        If I try to login, nothing works... but if I'm as guest I can "surf" on my zabbix, so I'm able to look at the triggers and it doesn't look good...
        Error in query [select * from events where objectid=12001 and object=0 order by clock desc limit 1] [Unknown column 'objectid' in 'where clause']
        mysql_fetch_array(): supplied argument is not a valid MySQL result resource[/.../apache/htdocs/zabbix/include/db.inc.php:398]
        Error in query [select * from events where objectid=12002 and object=0 order by clock desc limit 1] [Unknown column 'objectid' in 'where clause']
        I get this error for every single trigger I guess...
        • treyh
          • May 2007
          • 64
          ie7
          I can't login with ie7 either
          • Coder
            • Mar 2007
            • 38
            Guys anybody resolve this problem?
            • VeryNewbie
              • Feb 2007
              • 40
              no, I tought the problem was the .sql files, so I created the database again and ran the scripts, but I become the same error again...
              I have no Idea how to solve it
              • Coder
                • Mar 2007
                • 38
                Basically for this reason I had to return on version Zabbix 1.1.6
                I will wait, can be in version 1.4.1 will earn normally.
                • VeryNewbie
                  • Feb 2007
                  • 40
                  I could solve it... in my case the problem was here:
                  I put the values right here (in db.inc.php) :
                  <?php
                  global $DB, $DB_TYPE, $DB_SERVER, $DB_DATABASE, $DB_USER, $DB_PASSWORD;
                  $DB_TYPE = "MYSQL";
                  $DB_SERVER = "blabla:1234";
                  $DB_DATABASE = "zabbix";
                  $DB_USER = "zabbix";
                  $DB_PASSWORD = "test123";
                  function DBconnect(&$error)
                  $result = true;
                  $DB = null;
                  but it doesn't worked... so I changed it to here:
                  <?php
                  $result = true;
                  $DB_TYPE = "MYSQL";
                  $DB = null;
                  if(!isset($DB_TYPE))
                  and it works now
                  • treyh
                    • May 2007
                    • 64
                    fix
                    didn't work for me......zabbix 1.4
                    • Coder
                      • Mar 2007
                      • 38
                      What Db you use?
                      for Oracle need other changes!
                      • Mondo1287
                        • Jul 2007
                        I'm running a fresh install of 1.4 on gentoo x86 with mysql. I cannot log in as Admin on Firefox 2.0.0.5 (linux), or Konqueror, or IE7 on Vista. It just takes me right back to the login page. I can only log in with Firefox 2.0.0.3 on Vista. If I type garbage into the login I do get an error, typing the correct username Admin with a blank password results in no error and a redirect back to the login page.
                        • treyh
                          • May 2007
                          • 64
                          login on 1.4
                          there are login problems with 1.4, you need to install or upgrade to 1.4.1
                          • Mondo1287
                            • Jul 2007
                            Thanks, the new version did the trick.
