how to upgrade using apt-get ?
  • akiuni
    • Apr 2007
    I encounter a problem (http://www.zabbix.com/forum/showthread.php?t=3665) which can be solved by recompiling zabbix with an updated file (proc.c) or installing the last version (1.1.7)
    The problem is that I have installed zabbix using apt-get (version 1.1.4). So I don't have the srcs and I can't recompile zabbix...
    Is there a way to obtain a sources.list address so as to install the 1.1.7 ? Or must I download and recompile ? (including all other packages like MySql wich were installed with apt-get)
    Thanks in advance
