Is there anything I can tweak on FreeBSD to get these to work properly? This box is also running my zabbix_server daemon. I am running version 1.4.
979:20070602:170101 Parameter [net.if.in[eth0,bytes]] is not supported by agent on host [Vismon] Old status [0] 983:20070602:170101 Parameter [net.if.out[eth1,bytes]] is not supported by agent on host [Vismon] Old status [0] 980:20070602:170101 Parameter [net.if.in[eth1,bytes]] is not supported by agent on host [Vismon] Old status [0] 980:20070602:170102 Parameter [proc.num[,,run]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170103 Parameter [proc.num[httpd]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170103 Parameter [proc.num[zabbix_server]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170103 Parameter [net.if.in[lo,bytes]] is not supported by agent on host [Vismon] Old status [0] 978:20070602:170103 Parameter [sensor[temp2]] is not supported by agent on host [Vismon] Old status [0] 978:20070602:170103 Parameter [net.if.out[lo,bytes]] is not supported by agent on host [Vismon] Old status [0] 978:20070602:170103 Parameter [proc.num[sshd]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170104 Parameter [proc.num[inetd]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170104 Parameter [proc.num[]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170104 Parameter [filesize[/var/log/syslog]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170104 Parameter [net.if.out[eth0,bytes]] is not supported by agent on host [Vismon] Old status [0] 983:20070602:170105 Parameter [system.cpu.util[,wait,avg1]] is not supported by agent on host [Vismon] Old status [0] 983:20070602:170105 Parameter [proc.num[mysqld]] is not supported by agent on host [Vismon] Old status [0] 983:20070602:170105 Parameter [sensor[temp1]] is not supported by agent on host [Vismon] Old status [0] 980:20070602:170106 Parameter [proc.num[zabbix_agentd]] is not supported by agent on host [Vismon] Old status [0] 980:20070602:170106 Parameter [system.swap.size[,free]] is not supported by agent on host [Vismon] Old status [0] 979:20070602:170106 Parameter [proc.num[syslogd]] is not supported by agent on host [Vismon] Old status [0] 979:20070602:170106 Parameter [vfs.file.cksum[/vmlinuz]] is not supported by agent on host [Vismon] Old status [0] 979:20070602:170106 Parameter [sensor[temp3]] is not supported by agent on host [Vismon] Old status [0] 980:20070602:170107 Parameter [vfs.fs.inode[/opt,free]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170107 Parameter [system.boottime] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170107 Parameter [vfs.fs.inode[/opt,pfree]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170107 Parameter [system.swap.size[,pfree]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170108 Parameter [system.swap.size[,total]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170108 Parameter [vfs.fs.inode[/opt,total]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170110 Parameter [vfs.fs.size[/opt,pfree]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170110 Parameter [vfs.fs.size[/opt,pused]] is not supported by agent on host [Vismon] Old status [0] 983:20070602:170111 Parameter [vfs.fs.size[/opt,total]] is not supported by agent on host [Vismon] Old status [0] 980:20070602:170111 Parameter [vfs.fs.size[/opt,free]] is not supported by agent on host [Vismon] Old status [0] 978:20070602:170112 Parameter [vfs.fs.size[/opt,used]] is not supported by agent on host [Vismon] Old status [0] 982:20070602:170112 Parameter [vm.memory.size[cached]] is not supported by agent on host [Vismon] Old status [0] 981:20070602:170113 Parameter [vm.memory.size[buffers]] is not supported by agent on host [Vismon] Old status [0]
