Multiple Templates for one Host - Problem
  • urkle
    • Jun 2007
    • 14
    #16
    In include/hosts.inc.php around line 1122 in the "validate_templates" function comment out the second check (which is the check for duplicate applications)
    It should look like this..
    Yeah I know it disables the application duplicate check, but as many have found out. things work fine w/ dup applications between templates. and It contradicts Alexei own comment here where he encourages another user to duplicate the application across templates.
            function        validate_templates($templateid_list)
                    if(is_numeric($templateid_list))return true;
                    if(!is_array($templateid_list)) return false;
                    if(count($templateid_list)<2)   return true;
                    $result = true;
                    $db_cnt = DBfetch(DBselect('select key_,type,count(*) as cnt from items '.
                            ' where hostid in ('.implode(',',$templateid_list).') '.
                            ' group by key_,type order by cnt desc'
                    $result &= $db_cnt['cnt'] > 1 ? false : true;
                    /*$db_cnt = DBfetch(DBselect('select name,count(*) as cnt from applications '.
                            ' group by name order by cnt desc'
                    $result &= $db_cnt['cnt'] > 1 ? false : true;*/
                    return $result;
    • radamand
      • Aug 2008
      • 89
      #17
      Im running 1.4.5 and having the same exact problem. I even went thru and dissassociated all applications from one of the templates. It still wont let me link the two templates to the same host.
      • pierre-hoffmann
        • Jan 2008
        • 133
        #18
        Perhaps the two templates contains the same applications name... i've often this problem; i think it's not a bug !
        P.Hoffmann
        System & Network Admin.
        __________________________
        Zabbix version 1.8.1
        Hosts monitored 1300
        OS Novell SLES 10 SP2
        • radamand
          • Aug 2008
          • 89
          #19
          Actually, I think it is, I rebuilt one of the templates with a new name, EXACTLY like the old one. Unlinked both templates from the host, saved, then added the templates back (using the newly created copy), and it worked fine.
          but, either way, i got it to work so..... There's quite a few odd little idiosyncracies in the Zabbix interface, most are fairly minor, but still annoying.
          • vrtareg
            • May 2006
            • 293
            #20
            Hi
            I expecting the same problem.
            I found that this problem caused when I add applications to templates.
            In different templates I add the same applications and try to link these templates to one host.
            I disable check for applications part in hosts.inc.php function validate_templates.
            Version of zabbix: 1.6.
            Areg
            • vinny
              • Jan 2008
              • 145
              #21
              In fact this problem is very old....and very annoying in a prod environment...
              Aly,
              is it possible to get rid of it ?
              Zabbix 1.8.3, 1200+ Hosts, 40 000+ Items...zabbix's everywhere
              • zabbix_es
                • Apr 2007
                • 153
                #22
                [zabbix-1.6] Any changes about this issue?
                Hello:
                I have also this issue "Error: conflict between selected templates" in version 1.6.
                What about that?
                It's a bug?
                • tekknokrat
                  • Sep 2008
                  • 140
                  #23
                  imo on the linking of some templates to a host the conflict checking should only check against application id and not the name of the application.
                  For application to work it then should suffice comparing the application name.
                  • bbrendon
                    • Sep 2005
                    • 873
                    #24
                    Having this issue with 1.6 build 6439
                    Edit: Fixed. I created a "services" application and had it created in multiple templates. Zabbix didn't like it, though I did.
                    Unofficial Zabbix Expert
                    Blog, Corporate Site
                    • urkle
                      • Jun 2007
                      • 14
                      #25
                      Zabbix 1.6.x Patch
                      The issue still exists in the 1.6 releases, and it seems they do not wish to fix it. Here is my previous post with the fix.
                      I've attached my current patch that I'm applying to the 1.6.x releases of zabbix
                      • jmcnulty
                        • Nov 2008
                        • 33
                        #26
                        You can add my name to the list of people who want to see this functionality. Guess why I'm here, because I just bumped into it as well.
                        This problem seems to have been kicking around for a few years without resolution. Why It's a very logical thing to want to do, to create multiple templates specific to application groups. Seems barking mad that I have to invent unique application names for each template if I want to link them all to the same server.
                        • tekknokrat
                          • Sep 2008
                          • 140
                          #27
                          [zabbix-1.6.2]
                          I have this conflict problem appearing although no items/applications are appearing twice.
                          • tekknokrat
                            • Sep 2008
                            • 140
                            #28
                            This issue is still keeping me from adding additional templates to a host.
                            The error message that appears:
                            * Template with application [Log Files] already linked to the host
                            The problem is that there are no items configured with the Application Name 'Log Files' in none of the templates i am using here.
                            • richardkraal
                              • Jul 2008
                              we've got problems to,
                              sometime we use the same items in different templates
                              in some cases we want both templates added to the same host
                              also using the same applications in different templates is a problem
                              this is causing big problems because we can not add new hosts to our monitoring system
                              • urkle
                                • Jun 2007
                                • 14
                                #30
                                I'd actually see this as a completely different issue than the one in this thread. Since having the same item in multiple templates creates a new set of issues. Mainly which item takes precedent? In other words, which name will be used, which application linkage will be used? Having this scenario creates a lot of ambiguity. It may be worth looking into reworking your templates to move these "common" items into another template.
                                Hmm.. I wonder if create a template with your shared item and linking that tempate to your two other templates would work?
                                ie.
                                host
                                => link Template A
                                => inks to Shared Template Z
                                => link to Template B
                                At least then, in theory, Zabbix should know that the item is the SAME as it's linked to the sub-template. However, theory is not reality and I'm not sure if zabbix would pick up on that at the moment. I'd suggest posting a new thread on this topic (since it is different, although related, from this topic)
