Monitoring named
  • renzo
    • Oct 2004
    Monitoring named
    Hi all,
    Is zabbix capable of monitoring availability of the named service?
    Not only through a ICMP ping, but rather looking for the service
    on the local client machine?
    /Renzo
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Crontab job?
    ZABBIX does not suport this natively.
    I would suggest creating a crontab job which would run a script checking availability of DNS. If DNS is up and running, send (zabbix_sender) 1 to ZABBIX server (zabbix_trapperd), 0 - otherwise.
    I do not recommend using the script as a User Parameter because this may lead to frequent timeout situations.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • renzo
      • Oct 2004
      How?
      Hi again,
      How can i implemented that?
      I mean, how can i send a 1 to the server, if not through the UserParamter?
      /Renzo
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Very briefly:
        Use zabbix_sender. The binary sends data to ZABBIX server.
        Run also zabbix_trapperd (server side) which will receive the data, process it and put into the database.
        Alexei Vladishev
        My Twitter
        • renzo
          • Oct 2004
          Documentation...
          Where can i find the documentation for zabbix_sender?
          /Renzo
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            ZABBIX Manual
            PDF version of the ZABBIX Manual contains information about all binaries. The Manual is part of ZABBIX v1.0 distribution.
            Also you may run ./zabbix_sender --help to get list of its command line parameters.
            Alexei Vladishev
            My Twitter
