newbie question on triggers
  • grabber
    • Mar 2005
    • 85
    Is there a document just for triggers. The information I can find seems a bit sketchy, also in existing triggers the hostname is used but if I try to create a new trigger with the same hostname zabbix tells me there is no host by that name
    example:
    {fw-trads-2:ifInOctets1.delta(0)}>150000 is accepted
    {fw-trads-2:status.last(0)}=2 is not accepted [ERROR:Invalid trigger expression. No such host (fw-trads-2) or monitored parameter (status)] this is an snmp host and I want to monitor it's availabilty, I realise now that "satus" is only used with the agent so apart from the host issue how do I set a trigger based on availability? currently this box is offline but zabbix is showing it as ok in the maps screen
    this is really confusing now.
  • sauron
    • Jan 2005
    • 215
    Read docs. status item overable only you used zabbix agent
    • grabber
      • Mar 2005
      • 85
      That's what I said above...the question is...how do I record the status of an snmp device, can I somehow use the availbel info. from the hosts screen?
      what about the host name issue....any ideas?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Obviously you haven't created an item with key 'status', that's why it complains.
        You may monitor availability (status) of a host if the host has either ZABBIX or SNMP agent running.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
