am getting to grips with this, still not quite got the snmptrapd sorted, but have noticed a problem in the formatting, so will switch to a perl script instead and do it my way
I am not using any agents at all, i am doing ALL SNMP polling stats, and have noticed a confusing situation when the polled host does not respond.
If a poll response does not come back, no entry is put into the database.
This is fine for the occasional missed packet, as the graphs will smooth out.
But, when a host does not respond for a longer period, i think it should log at least something.
This show a 15 minute gap in polling, due to a host rebooting.
2004.Oct.10 14:53:34 331.7907
2004.Oct.10 14:52:51 1185.4722
2004.Oct.10 14:37:50 350.8108
2004.Oct.10 14:37:13 290.5278
However, the graph is only noticeable when viewed to the exact hour, because there is a long straight line between the events.
On the daily graph, it look like the host never went down!
Would it be possible to set a configurable option for what to log after so many missed polls ?
EG 5 missed polls then log a 0 into the database (numeric) or no response (character)
Or make it a default to log 0 or nothing, but still make a log entry, rather than make no log entry at all.
Regards,
Craig
Regards,
Craig
