cumulative disk io operations in new clients
  • ProTON
    • Oct 2005
    • 77
    i've used io[disk_io] items on my servers to monitor cumulative disk read and write io operations. Recently I've upgraded zabbix client to version 1.4 and saw that io[disk_io] is no longer available. Instead there are vfs.dev.read and vfs.dev.write, however I want to get this information in one trigger. Is there a way to do this as I don't need that information be seperated and also this way zabbix database will be a lot smaller (I monitor houndreds of disks).
    Best Regars,
    ProTON
  • ProTON
    • Oct 2005
    • 77
    Anyone
    • testos
      • Apr 2007
      • 85
      In my opinion, triggers expressions only working with items values.
      You can set keep history and trends items fields to 1 for minimize database load.
      • ProTON
        • Oct 2005
        • 77
        Erm, I ment "i want to do it in one item". I don't use triggers on these items, but I must keep history and trends info for another 1 to 3 months.
        • ProTON
          • Oct 2005
          • 77
          I'm still searching for a solution on this issue. Can't upgrade to 1.4 until it is solved
          • DiedX
            • Oct 2004
            • 106
            I thought that it was possible to have a item from 2 items?
            OTOH: reads and writes *ARE* different things, so why exactly do you need it to be together?
            https://www.diederik.nl
            • ProTON
              • Oct 2005
              • 77
              [QUOTE=DiedX]I thought that it was possible to have a item from 2 items?/QUOTE]
              What is the way to do this?
