As you know, a MSSQL instance can be declared SERVER\INSTANCE, each instance of this type has two services, one engine and one agent.
The services names follows this pattern
MSSQL$INSTANCE
SQLAGENT$INSTANCE
Then a Zabbix Item should be service_state[MSSQL$INSTANCE], an the trigger on service not runnig should be {host:service_state[MSSQL$INSTANCE].last(0)}>0
but when i try to save this i get an error about this key doesn't exists.
I think the problem is the "$" character, how can I save this trigger???.
Thanks in advance.
MSSQL$INSTANCE
SQLAGENT$INSTANCE
Thanks in advance.
