I add to my monitoring 2 snmp device.
Add host: xxx:1.1.1.1, yyy:2.2.2.2
Add item: AverageSNR:snmpv1 agent, oid AAA, key BBB, aplications Avalibality.
2 snmp device was successfully added to Map.
First device work fine and it status OK.
Second device tell me in configuration -> host -> avalibality - not available !!! time out while connection to yyy....
But at the MAP status of the second device also OK!!! Why ??? What i need to do to view Actual status of this device???
I add trigger... and all work FINE... Thanks...
I'm right ?????????
I'm right ?????????
