Monitoring server performance problems
  • charles
    • Sep 2004
    • 54
    Hi
    we have been plagued with perforance problems on our zabbix monitoring server. It's no slouch - dual 2.8G xeon with 2G of RAM. Disks are IDE, but sufficient (but this could be the issue).
    Load goes from 0 to 4-6 when we start the suckerd (currently running 8 as we had a queue backlog with fewer).
    Load appears to mostly be mysql taking cpu, and occasionaly suckerd, but I have noticed a very large number of local connections (127.0.0.1) to services like smtp/pop/imap when zabbix is running. if I shut off zabbix they stop. I checked the host definition for the monitoring server and it isn't configured to check those ports. I even deleted that host, but it doesn't stop.
    Any way to check if we have some sort of misconfiguration causing those checks to check localhost instead of the actusal server it should be (because thats whhat it seems is happening).
    FYI, We are about to try run sql on another server, mainly because zabbix is crippling all the other services on the current server, but hope it will help zabbix as well. We have had corrupted history tables several times now.
    Any thoughts?
    thanks
    charles
    Is zabbix_suckerd running ? Yes
    Is zabbix_trapperd running ? No
    Number of values stored 229843285
    Number of trends stored 26340362
    Number of alarms 75270
    Number of alerts 1965
    Number of triggers (enabled/disabled) 3386(3385/1)
    Number of items (active/trapper/not active/not supported) 6636(5721/0/174/741)
    Number of users 16
    Number of hosts (monitored/not monitored) 296(271/8)
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    The hardware seems to be quite adequate to the stats. Be aware that when you start ZABBIX server it starts performing housekeeping procedure which is quite resource hungry. So, CPU (and disk) load can go up for several minutes, and then return to 'normal' values.
    Are you sure you have no servers with local hostname, 127.0.0.1 or IP address of your server defined in ZABBIX database? Please, double-check it. It is highly doubtful that ZABBIX does something it is not supposed to do.
    Please, let me know about any progress made. Thanks!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • charles
      • Sep 2004
      • 54
      Hi Alexei
      I hope you are well, and I see you started a commercial entity for Zabbix! Excellent!
      I should have mentioned we stopped it because the load was too high in general and causing us pain to use all the other services in the box. So it's not just startup.
      I did check for the hostnames, but unless I am not checking correctly, this is not it. As you can see I even deleted it to be sure
      mysql> select * from hosts where ip='127.0.0.1' or host like 'dtg000%';
      | hostid | host | useip | ip | port | status | disable_until | network_errors |
      | 10035 | DTG000 [DELETED] | 1 | 127.0.0.1 | 10005 | 4 | 1114008460 | 3 |
      1 row in set (0.00 sec)
      I'll let you know what we see once I move the DB to a dedicated P4 2.4ghz 1G RAM with 2x36gb 10krpm scsi drives software raid 1 connected via private gigabit ethernet.
      charles
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Hi Charles,
        I'm fine, thanks! I hope you're all right too.
        The host obviously has another IP address.Have you tried "select * from hosts where ip='<host IP>'"?
        What database format you're using, MyISAM or Innodb? Is MySQL configured and tuned to use most of available memory?
        Alexei Vladishev
        My Twitter
        • charles
          • Sep 2004
          • 54
          Hi Charles,
          Good thanks.
          Yes, and by various possible hostnames (we don't use IP much). Still only that one row.
          MyISAM. It's probably not tuned the best. I'd like to hear you recommendations for my size (only getting bigger), and I will try them on both this server and the new one.
          Thanks!
          charles
