HOWTO Install Zabbix 1.4.2 from source (usefull for all systems)
  • aalexanderr
    • Jul 2007
    • 26
    Install Zabbix 1.4.2 from source !!!
    1)
    ls /tmp/installs
    curl-7.16.3.tar.gz libxml2-sources-2.6.29.tar.gz
    fping-2.4b2.tar.gz mysql-5.0.41.tar.gz
    gd-2.0.35.tar.gz net-snmp-5.4.tar.gz
    httpd-2.2.4.tar.gz perl-5.8.8.tar.gz
    jpegsrc.v6b.tar.gz php-5.2.3.tar.gz
    libiconv-1.11.tar.gz prezabbix-1.4.2.tar.gz
    libpng-2.1.18.tar.gz zlib-1.2.3.tar.gz
    2)
    cd /temp/installs
    tar -xvpf curl-7.16.3.tar.gz
    tar -xvpf libxml2-sources-2.6.29.tar.gz
    tar -xvpf fping-2.4b2.tar.gz
    tar -xvpf mysql-5.0.41.tar.gz
    tar -xvpf gd-2.0.35.tar.gz
    tar -xvpf net-snmp-5.4.tar.gz
    tar -xvpf httpd-2.2.4.tar.gz
    tar -xvpf perl-5.8.8.tar.gz
    tar -xvpf jpegsrc.v6b.tar.gz
    tar -xvpf php-5.2.3.tar.gz
    tar -xvpf libiconv-1.11.tar.gz
    tar -xvpf prezabbix-1.4.2.tar.gz
    tar -xvpf libpng-2.1.18.tar.gz
    tar -xvpf zlib-1.2.3.tar.gz
    3)
    #cd ../perl-5.8.8
    #./configure.gnu --prefix=/usr/local && make && make install
    4)
    #cd ../zlib-1.2.3
    #./configure --prefix=/usr/local && make && make install
    5)
    #cd ../libpng-2.1.18
    6)
    #cd ../jpeg-6b
    #./configure --prefix=/usr/local --enable-shared --enable-static && make && make install
    7)
    #cd ../gd-2.0.35
    #./configure --prefix=/usr/local --x-includes=/usr/local/include --x-libraries=/usr/local/lib && make && make install
    8) cd ../httpd-2.2.4
    #./configure --preifx=/usr/local/apache2 --enable-so && make && make install
    #ee /usr/local/apache2/conf/httpd.conf: DirectoryIndex index.php index.html
    #ee /usr/local/apache2/conf/httpd.conf: Addtype application/x-httpd-php .php
    9)
    #adduser username=mysql shell=nologin password=mysql
    #cd mysql-5.0.41
    #./configure --prefix=/usr/local/mysql --with-client-ldflags=-all-static --with-mysqld-ldflags=-all-static --disable-shared --enable-assembler --without-bench --without-man --without-docs --without-debug --with-berkeley-db --with-charset=koi8r --with-extra-charsets=none --localstatedir=/usr/local/mysql/data --with-mysqld-user=mysql --disable-large-files --with-libwrap && make && make install
    #mkdir /usr/local/mysql/data
    #/usr/local/mysql/bin/mysql_install_db
    #chown -R root:mysql /usr/local/mysql
    #chown -R mysql:mysql /usr/local/mysql/data
    #chmod -R 755 /usr/local/mysql/data
    9)
    #cd ../libxml2-2.6.29
    #./configure --prefix=/usr/local --with-zlib && make && make install
    #cd ../libiconv-1.11
    10)
    #cd ../php-5.2.3
    #./configure --with-mysql=/usr/local/mysql --enable-bcmath --with-gd=/usr/local --with-jpeg-dir=/usr/local --with-png-dir=/usr/local --with-zlib --with-apxs2=/usr/local/apache2/bin/apxs --disable-cgi --disable-ipv6 && make && make install
    #cp php.ini-recommended /usr/local/lib/php.ini
    #ee /usr/local/lib/php.ini
    doc_root = "/usr/local/apache2/htdocs/"
    max_execution_time = 300
    date.timezone = Europe/Moscow
    11)
    #cd ../net-snmp-5.4
    #./configure --prefix=/usr/local --disable-debugging --disable-manuals && make && make install
    12)
    #cd ../curl-7.16.3
    #./configure --prefix=/usr/local --disable-ipv6 --without-ssl && make && make install
    13)
    #adduser (username=zabbix shell=nologin password=zabbix)
    #cp /usr/local/lib/libcurl* /usr/lib/
    #cd ../zabbix-1.4.2
    #./configure --enable-server --enable-agent --enable-static --with-mysql=/usr/local/mysql/bin/mysql_config --with-net-snmp --with-libcurl=/usr/local/bin/curl-config && make && make install
    #mkdir /etc/zabbix
    #cp ./misc/conf/zabbix_server.conf /etc/zabbix/zabbix_server.conf
    #chmod –R 700 /etc/zabbix
    #chown –R zabbix:zabbix /etc/zabbix
    #rm -rf /usr/local/apache2/htdocs/*
    #cp -rf ./frontends/php/* /usr/local/apache2/htdocs/
    #chmod -R 755 /user/local/apache2/htdocs
    #ee /etc/zabbix/zabbix_server.conf
    FpingLocation=/usr/local/sbin/fping
    PingerFrequency=30
    14)
    #cd ../fping-2.4b2
    #./configure && make && make install
    #chown root:zabbix /usr/local/sbin/fping
    #chmod ug+s /usr/local/sbin/fping
    15)
    #/usr/local/mysql/bin/mysqld_safe --user=mysql &
    #/usr/local/mysql/bin/mysql -u root
    mysql> create database zabbix;
    mysql> grant all on zabbix.* to zabbix@localhost identified by 'zabbix';
    mysql> exit;
    # cd create/schema
    #/usr/local/mysql/bin/mysql -u zabbix --password='zabbix' zabbix < mysql.sql
    # cd ../data
    #/usr/local/mysql/bin/mysql -u zabbix --password='zabbix' zabbix < data.sql
    #/usr/local/mysql/bin/mysql -u zabbix --password='zabbix' zabbix < images_mysql.sql
    Run you browser address http://serverip, follow instructions. (Mysql -> localhost, base -> zabbix, username -> zabbix, password -> zabbix). Save config zabbix.conf.php to /usr/local/apache2/htdocs/conf/
    #chmod -R 755 /usr/local/apache2/htdocs/conf/zabbix.conf.php
    Login: admin
