All is status unknown
  • diegocito
    • Jun 2007
    • 22
    My question is very simple : when I declare a host, an item or a trigger, there are all always at the status unknown.
    I have read all discussions about it, but no solution.
    Please, help me!!
    Diegocito.
  • diegocito
    • Jun 2007
    • 22
    Actually, I have the impression that all the problems of the forum are in my installation : I have no graph (no data)
    I have no value in "last value"
    The field "last change" is at "Never"
    Nevertheless, when I 'am in the configuration field : my host is on the status : "monitored".
    Diegocito
    • swaterhouse
      • Apr 2006
      • 268
      Are the zabbix_server and the zabbix_agentd prcesses running?
      Scott
      • diegocito
        • Jun 2007
        • 22
        The server yes, but not the agent, because I have to monitorate by snmp : so no need agents, but for the moment, I tested a simple check : icmpping, with the trigger : "my_host:icmpping.max(300)<1" (the syntax is correct, no??).
        I will notice you that I have also the "snmpd" running. (even if I know it's not needed for icmpping...).
        Thanks for the answer.
        Diegocito
        • diegocito
          • Jun 2007
          • 22
          Originally posted by predatorz
          Erm okay i added simple check item<[tcp,port], i just put tcp> into my ping template(which has icmpping, icmppingsec) and once saved, all the previous unknown availability all becomes available....
          I do the same, and as predatorz, my host status became available, and tcp work (graph, last value...).
          However, icmpping and icmppingsec don't work (status unknown).
          But I said tcp works, but in fact, the value is always 0 => TCP down.
          For information, I tried to monitor a Cisco switch.
          Thanks,
          Diegocito
          • diegocito
            • Jun 2007
            • 22
            Solved
            In fact, my boss had not changed the IP which could connected to the switch.
            That's why I can't connect and collect informations.
            Nevertheless, I have another problem because snmp works but not simple checks as "icmpping"
            A+
            Diegocito
            • diegocito
              • Jun 2007
              • 22
              Precisions
              For information, I have installed fping, and when I try to ping my switch via command line, it works.
              I nothing understands there.
              Diegocito
