it says "Apache is not running on {HOSTNAME}" but it is running
If the process isnt called apache2, then it wont be able to find it. The httpd process is usually apache 1.3, and not apache2 btw.
??? Maybe if you install through a package or something, we have several 2.0.54 and 2.0.58 apaches and the process is still httpd....
Besides, I'm kinda dumb but not THAT dumb, the item has httpd as a parameter (and also, I'm testing this localy entering the parameter manually as well...)
