some database backup queries plz help..
  • bluesurfer
    • Jul 2007
    • 11
    Hi
    I need to do a database backup from 1 zabbix server to another new zabbix server. the old zabbix server's database is a old version while the new zabbix is a recent version. I m using mysql database. wanna ask how to do this backup??on the old zabbix i used mysqldump to get the data out. so do i need to do anything before i dump the data into the new zabbix server? Thanks a lot!
  • swaterhouse
    • Apr 2006
    • 268
    Just load the old data into the new server and run the upgrade scripts for the new version.
    • bluesurfer
      • Jul 2007
      • 11
      erm...as in run the upgrade script for the new zabbix server?so i pump the data into the database den i run the upgrade script?
      • swaterhouse
        • Apr 2006
        • 268
        Yes that should be all you need to do.
        • bluesurfer
          • Jul 2007
          • 11
          oh man...how do i put the xx.sql data back in??and erm to run the script izit ./<scriptname> ? erm so sorry..quite new to linux and was thrown this task...
          • bbrendon
            • Sep 2005
            • 873
            Unofficial Zabbix Expert
            Blog, Corporate Site
            • bluesurfer
              • Jul 2007
              • 11
              hi,
              i have used mysqldump to get the data out from the database...so how do I put the extracted data into another database??also use mysqldump?? den how do u run the script??i tried ./patch.sql they say its not exceutable file..==''
              • bluesurfer
                • Jul 2007
                • 11
                help..!how to run the patch.sql script in zabbix-1.4.1/upgrades\dbpatch\1.4\mysql\patch.sql ???help me plz..!
                • gescheit
                  • Jul 2007
                  • 156
                  mysql -D zabbix -p < patch.sql
                  • bluesurfer
                    • Jul 2007
                    • 11
                    when i did that, it says 'ERROR 1050 (42S01) at line 16: Table 'actions_tmp' already exists' y izit like tat??
                    • bluesurfer
                      • Jul 2007
                      • 11
                      hi guys...right now i am importing data into database..the data is worth 3.9Gb or disk space...and its beenimporting since 3 days ago... it is a little too long to import data of this size?? i used this command
                      $mysql -uroot -p testzabbix < test_zabbix.sql
                      is it correct??Is the import time too long or what?
