Does anyone know if its possible to create custom screen resources that have various snmp data for a given device. Similar to the layout of the "Server Info" resource, I would like to have a resource for snmp device that shows basic data like hostname, uptime, uname, device version, ip address, etc. A summary-type resource that can pull in some basic info about device. It would be great is this screen was configurable.
You can pull in a "Resource" & "Parameter" and just specify one line to get the latest value, but it makes for pretty messy screen when you create multiple instances int he same column, it would be nice to be able to specify multiple resource+parameter combinations within the same screen cell.
