what SNMP key to use ?
  • Philippe
    • Oct 2004
    • 77
    I use cisco 3550 routing switches in our network.
    Zabbix is also working like a charm and i already get snmp info like percentbusy and freemem but i would also like to get info if the routing is changing!
    The switches are configured from point A to point B with 2 routings in case that 1 fails.
    But if one fails, we don't know it...most of the times is the cable company that contacts us so i really would like to know it also.
    normally there are OID codes but i don't know if there is a zabbix key for them.
    any solution ?
    thnx!
    Philippe
  • riegersteve
    • Oct 2004
    • 68
    use snmpwalk -Os to get the variable then use -On to get the OID for that variable which you can out into zabbix
