Cross-template triggers
  • x0tsing
    • Feb 2007
    • 20
    I recently upgraded to Zabbix v1.4 and am now in the process of organizing everything better.
    I used to have all items and triggers in the windows_t template. I now have an Exchange template for monitoring my Exchange servers, a SQL template for the database servers, etc. I used the Copy function to copy the items from the windows_t template to the appropriate new one, then deleted it from windows_t. I want to do that now with the triggers, but I am getting an error: "Missing key 'eventlog[Application]' for host 'Exchange'"
    The Trigger expression is: ({Windows_t:eventlog[Application].logsource(MSExchangeIS Mailbox Store)}=1)&({Windows_t:eventlog[Application].logseverity(2)}=2)
    Apparently it's looking for the event log item in the Exchange template and not finding it, which makes sense. When I tried copying the expression directly into a new trigger form while in the Exchange template, it simply created it under the Windows_t template instead.
    Is there a way to reference items from a different template?
  • x0tsing
    • Feb 2007
    • 20
    Anybody?
    Does anyone know the answer to this?
    • dratliff
      • May 2007
      • 40
      There is a thread about this, I am not sure where. I upgraded by test machine to the 1.4.1 agent and then my eventlog items wouldn't work. It is a known bug and I believe 1.4.2 will address it.
      • x0tsing
        • Feb 2007
        • 20
        It's not so much the agent I'm having problems with. I'm running the old agent, and it's still pulling event logs fine. But I gather the event logs in one template, and I want to use them in triggers from another template. I want to be in the Exchange template's triggers and access the event logs that were gathered in the Windows_t template. I haven't been able to find the thread on this. Could someone point me in the right direction? Thank you so much.
        • x0tsing
          • Feb 2007
          • 20
          I'm still unable to find any information on how to do this. Does anyone know where to look?
