E-Mail Client
  • pdtec
    • Jul 2007
    • 11
    E-Mail Client
    hi,
    which e-mail client does zabbix use or can i define that manually?
    greetz pdtec
  • cstackpole
    • Oct 2006
    • 225
    I believe that it uses whatever is defined for the command 'mail' on the system. On one test system I have postfix being used but I tend to use exim for the others.
