I am trying to install Zabbix 1.4.1 on a x86_64 machine running FC6. I am getting the following error while running the "configure" command. I am using postgres as the DB and I also have enabled SNMP support, Jabber messaging and web client support.
The "configure" command and the last few lines of its output (containing the error message) is shown below:
# ./configure --enable-server --with-pgsql --with-net-snmp --with-jabber --with-libcurl --enable-static
checking for pg_config... /usr/bin/pg_config
checking for PostgreSQL libraries... yes
checking for ZABBIX server database selection... ok
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for IKSEMEL... yes
checking for getaddrinfo... yes
checking for gawk... (cached) gawk
checking for curl-config... /usr/bin/curl-config
checking for the version of libcurl... 7.15.5
checking for libcurl >= version 7.15.1... yes
checking for main in -lgssapi_krb5 ... no
configure: error: Not found gssapi_krb5 library
If I don't specify the "--enable-static" option to the command, then everything is OK and I am able to build the binaries. But I want to do a static linking while creating the zabbix binaries.
Also, the output of /usr/lib64/libgssapi_krb5* is shown below:
-rw-r--r-- 1 root root 458306 Jun 27 12:22 /usr/lib64/libgssapi_krb5.a
lrwxrwxrwx 1 root root 21 Aug 13 13:49 /usr/lib64/libgssapi_krb5.so -> libgssapi_krb5.so.2.2
lrwxrwxrwx 1 root root 21 Aug 13 13:27 /usr/lib64/libgssapi_krb5.so.2 -> libgssapi_krb5.so.2.2
-rwxr-xr-x 1 root root 171528 Jun 27 12:22 /usr/lib64/libgssapi_krb5.so.2.2
Can anyone please let me know what the problem is. Thanks a lot for your help.
Regards,
Nandu
Regards,
Nandu
