Value mapping in notifications
  • dreas
    • Aug 2007
    • 89
    A search on this forum revealed 0 topics about value maps. I have several triggers that send an email notification when something is wrong. This works fine. I want the value of the error however included in the notification. That way I can quickly see what is possibly going wrong. Right now I just get "Trigger Test: ON" or "Trigger Test: OFF" but it should be "Trigger Test: ON (1 TriggerTestValue1)" and "Trigger Test: OFF (0 TriggerTestValue0)".
    How can the value mappings be added to the notifications? They show fine under Latest data.
  • stkr
    • Feb 2007
    • 18
    I have the same question. It is possible to send the value mapping code in an action notification.
    e.g. value map name = FTP Server
    Value: 1 => "Up"
    Value: 0 => "Down"
    action mail:
    FTP STATUS: "Down" (0)
    I use version 1.1.6
    thx for help
    stkr
    • stkr
      • Feb 2007
      • 18
      I found the solution
      In the Message field of New Action write e.g.:
      Value: {{HOSTNAME}:{TRIGGER.KEY}.last(0)}
      This gives the output of the value map.
