Templates and modified triggers
  • phlux
    • Aug 2007
    • 11
    All,
    I think that the windows template is lacking a bit.
    Have many of you modified the template at all? Have you added in your own triggers?
    I need to monitor a specific service on all the windows servers, I cannot see how to add this trigger based on the template. How may I do this? I would think that this would be very straightforward - maybe I am not looking in the right place (for info).
    Anyone care to share their templates here if they have tweaked them a bit.
  • rolandsym
    • Jul 2007
    • 76
    windows services
    If you look at the Windows Template you will see where it keeps track of the dhcp client.
    service_state[Dhcp] is the key
    all you have to do is replace Dhcp with your service name. You can get that name by going to the services mmc and bring up the properties of the service you want to monitor it's up/down status. In the General tab you should see a field called Service name. The value that follows that you put in the brackets above. For example, if I wanted to monitor the "workstation" service then my key would be
    service_state[lanmanworkstation]
    Does this help?
    Rolandsym
    • phlux
      • Aug 2007
      • 11
      Roland,
      Thank you - that is exactly what i was looking for.
      Alexei - this should be clearly documented some place if it isnt already
      Sam
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        I added some brief details to the manual
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
