pre-requisites problems
  • metan
    • Aug 2007
    Hye all. I'm trying to install last version of Zabbix, and got a problem on pre-requisites section :
    PHP max execution time:	30 sec	Fail
    PHP Timezone:	n/a	Fail
    But my php.ini is correctly configured :
    date.timezone =  Europe/Paris
    max_execution_time = 300
    And Apache is restarted of course. Do you know whats wrong ? Thanks in advance.
  • psedo
    • Aug 2007
    • 10
    Same problem !
    I have the same problem, but just for date.timezone !
    Previously I set :
    date.timezone = "Europe/Paris"
    In pre-requisites section I had the error for 'date.timezone' so I changed to :
    and restart httpd, but always the same error, like if no taking new configuration !? The php.ini is reloaded at each restart of httpd ?
    Thanks in advance
    (and sorry for my english!!)
    • psedo
      • Aug 2007
      • 10
      Oups
      I forbidden to delete the ';' for comment !!!
      Maybe its the same for you !!
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        That's why I don't waste time responding to all problem reports immediately. Some "problems" tend to be resolved automagically
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • metan
          • Aug 2007
          Lol I would like to have done the same error but it is not the case :
          [Date]
          ; Defines the default timezone used by the date functions
          So now alexi if you have an idea, it would be the good momet to explain it, thanks :=)
          • krltech
            • Sep 2011
            same issue
            I have the same problem also
            i have installed 1.8.7 on debian and the setup.php web install keeps giving me the following results on the 3rd step
            PHP version 5.3.3-7+squeeze3 5.0 5.3.0 Ok
            PHP post max size 8M 16M 32M Fail
            PHP max execution time 30 300 600 Fail
            PHP max input time -1 300 600 Fail
            PHP timezone no Fail
            Fail
            I have found only two php.ini files and i have3 edited them correctly
            i have restarted both apche2 and the server
            i have also rebooted
            I am not sure why apache dosnt seem to be reading the php.ini file
            has anyone any ideas
