Does anyone know if the 1.4.1 version of the AIX (v5.3) agent supports system.run commands?
I had a lot of system.run commands to capture metrics in the previous version of Zabbix (v1.1). After I upgraded to the newer version of the agent, the system.run commands went to a status of unsupported.
If 1.4 does not support system.run commands, does anyone know of a substitute?
Thanks,
Sid
Thanks,
Sid
