Hi
I have set up a test simple check ssh,192.168.2.77,22 to check that a machine it up using the ssh port on it .. but it does not reflect true values .. when I shut the machine down, it showed down for a bit then when back to showing that the device was available , even though it's swiched off .. what could be wrong ?
using zabbix 1.4.2 .
this are the results of the log file .. which contradicts the manual by my understanding .
8906:20070823:152620 Deleted 0 records from history and trends
8884:20070823:153210 Too many parameters in [ssh,192.168.2.77,22]
8884:20070823:154210 Too many parameters in [ssh,192.168.2.77,22]
8884:20070823:155210 Too many parameters in [ssh,192.168.2.77,22]
8884:20070823:155235 Too many parameters in [ssh,192.168.2.77,22]
8884:20070823:155235 Parameter [ssh,192.168.2.77,22] is not supported by agent on host [seyos1] Old status [0]
8884:20070823:160235 Too many parameters in [ssh,192.168.2.77,22]
