Resetting Triggers
  • trikke
    • Aug 2007
    • 140
    Resetting Triggers
    Hi ,
    ist there a possibility to reset all/some triggers, so that the next intervall, all the actions are executed again?
    Thanx
    Patrick
    Using P.S.: Zabbix 1.4.2 on Sun Solaris with mysql
  • trikke
    • Aug 2007
    • 140
    Problem solved!
    I did some reverse engineering and found out, if I would delete the Events corresponding to the Item/Trigger, Triggers and Actions will be fired again.
    Delete Events with following sql: "delete from events where objectid=<your object id>;" Where objectid = triggerid
    Other possibility is depending on your Triggerdefinition alter the Item Lastvalue, so that u simulate a item state change.
    Use following SQL: "update items set lastvalue=0 where hostid=<hostid> and itemid=<itemID>;"
    Can someone confirm this??? Alexei ????
