Problem with default value mapping?
  • oliverm
    • May 2006
    • 155
    Hi.
    Im trying to monitor the W3SVC service on some windows boxes.
    The default value map for services says that a value of 0 is down and that 1 is up. However, zxabbix shows that the W3SVC isnt running, with a value of 0, but on ALL the servers the W3SVC service **IS** running. Stopping it changes the value to 1, which should be UP.
    IS there a problem with the default mapping ?
    Olly
  • NOB
    • Mar 2007
    • 469
    are you using the "service_state[service display name]" and
    the value map "Windows Service State" value map ?
    For me this works fine in 1.4.2
    Not much experience with checking for port 80.
    Up to now we do it with a different tool
    HTH,
    Norbert.
