Hi.
This is the first time i'm running zabbix. I'm using version 1.4.2 and have it up and running with the unix template.
I have come across a couple of things i don't know how to do.
1) I am running apache in the form of apache2 executable instead of httpd, thus having an alarm of web server not running. I have read a post saying that the solution is editing the item instead of the trigger, but i don't know where do i have to edit. Tried clicking on Configuration, Items screen, but it doesn't pop up any configuration or edition screen.
2) I have zabbix running on a dual core machine. Output of sensors is the following:
I have read that some changes should be done so that zabbix can read temperature for both cores, but I still don't know where or what to change.
Thanks in advance for your time.
Javier.
w83627dhg-isa-0290
Adapter: ISA adapter
VCore: +1.16 V (min = +0.00 V, max = +1.74 V)
12V: +12.04 V (min = +10.82 V, max = +13.20 V)
AVCC: +3.28 V (min = +3.14 V, max = +3.47 V)
3VCC: +3.28 V (min = +3.14 V, max = +3.47 V)
VSB: +3.28 V (min = +3.14 V, max = +3.47 V)
CPU Fan: 1834 RPM (min = 1004 RPM, div = 8)
Sys Temp: +30 C (high = +35 C, hyst = +27 C) ALARM
CPU Temp: +39.0 C (high = +58.0 C, hyst = +46.0 C)
coretemp-isa-0000
Core 0: +42 C (high = +100 C)
coretemp-isa-0001
Core 1: +42 C (high = +100 C)
coretemp-isa-0000
coretemp-isa-0001
Javier.
