Negative values in 1.4.2
  • abtel
    • Aug 2007
    I´m put an item of snmp v1 and response of line command is -1, but the latest data of zabbix in this item is a value -9999999999.9999. This release function by negative numbers? Thanks
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Are you sure you are running 1.4.2?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • BusteR81
      • Apr 2007
      • 150
      zabbix_trapper
      running 1.4.2 here and zabbix_sender does not accept negative value. i confirm and reconfirm even trying -o (value) & -i (input file)....
      zabbix_trapper just ignore -(value) from sender but works perfectly well with +ve(value) !!
