I am using Zabbix 1.4.2 and I want to do an external check using a script I wrote. I have created a scripts directory where I have put this script. I modified the zabbix_server.conf and specified this directory as the value for the "ExternalScripts" variable and restarted the zabbix server.
Now, what additional configuration should I do on the web client in order to see the effects of running this script? i.e. Should I define an "Action" or "Trigger" or both?
I don't see any status info on the web page right now for this script.
Thanks,
Nandu
Thanks,
Nandu
