external script wait time
  • BusteR81
    • Apr 2007
    • 150
    hi
    i had ran a script successfully from zabbix 1.4.2
    when host is healthy it will return value >0
    ELSE
    -1
    problem: when running script from SSH zabbix server and when system is healthy, the value (>0) will be returned instantly
    BUT
    if system is unhealthy, the value '-1' tends to return after 15-20 sec. Therefore zabbix_server.log shows timeout has occurs on reading the ITEM value from this script.
    Question: how can i INCREASE the external scripts WAIT time so that it will NOT timeout while waiting for a (-ve) value in my case ?
    cheer
  • BusteR81
    • Apr 2007
    • 150
    did a search on forums
    Type must be set to ZABBIX Agent and ZABBIX Agent (active). Make sure that your script is fast enough, ZABBIX won't wait longer than 3 seconds by default.
    HOW can i increase the 3 sec
    • BusteR81
      • Apr 2007
      • 150
      answers?
      no answers ? i did a turn around and tried using zabbix_trapper + zabbix_sender to obtain my Radius dB status data. but the SAD thing is trapper does not accpet negative (value) even in 1.4.2 and my alarm TRIGGERs at -(values)
      • ptietjens
        • May 2008
        Argh
        Too bad this was never answered. I too, now am stuck in a conundrum where I need to check that routes are up in my WAN - there is no function to do so in Zabbix, and no script I write is going to be able to transverse long routes in under 3 seconds.
        back to nagios, perhaps
        • BusteR81
          • Apr 2007
          • 150
          well good news for you, yes zabbix server wait only 3 sec to get a answer (int, float, char etc) from the script but after 3sec, the script will still be run in the background. that is, eg. (the script must return a value in 3 sec and thereafter the script may do a trace route of 1-2 min and send it the the NOC)
          for your case, u can return the value after " transverse long routes" by using zabbix_sender (trapper). look at zabbix_sender for details in the zabbix manual
          cheers
          • ptietjens
            • May 2008
            Trapper
            Yeah, that's the solution I arrived at, only I didn't bother with the external check, I just have those few (10) traceroutes done and sent to Trapper via CRON and it works fairly well.
            Perhaps a note about the three second limitation should be somewhere in the docs, eh?
            • lamont
              • Nov 2007
              • 89
              scanning through the sources, i suspect that the "Timeout=" variable in zabbix_server.conf applies to external checks as well as agent checks... not positive, however....
              • lamont
                • Nov 2007
                • 89
                I just bumped my Timeout= up to 10 and in the config table in the database decreased refresh_unsupported down to 60. I also took my external script and wrapped the whole thing with an alarm timeout (and validated that the libraries that i'm using call select() for a timeout and don't use SIGARLM themselves).
