Help me (icmppingsec)
  • SorrisoBR
    • Sep 2007
    SERVER CONFIGURATION:
    FpingLocation=/usr/sbin/fping
    PingerFrequency=30
    CONFIGURATION OF ITEM:
    Description: ICMP Time
    Type: Simple check
    Key: icmppingsec
    Type of information: Numeric (integer 64bit)
    Units: ms
    Use multiplier: custom multiplier
    Custom multiplier: 1000
    Update interval (in sec): 30
    FPing is work, because with icmpping value return 1.
    With icmppingsec my item is always 0. What do i do?
  • predatorz
    • Mar 2007
    • 109
    For type of information, Use float instead of integer
    • SorrisoBR
      • Sep 2007
      tks, worked!!!
