Hello! I'm trying to install Zabbix on a Red Hat Enterprise 4 with MySql.
I'm new on this, so my apologies if I say something wrong...
I get some documents about installation, and all of them tell that I need Mysql 3.22 or higher. I have Mysql 4.1. installed.
When I try to compile the server, it says that can't find Mysql Library.
In one on the docs I 've read, I see that I need libmysqlclient15-dev, and if I look for it, I find that it is a deb file, wich it is only for debian(I believe...)
My doubt is if I need libmysqlclient15-dev, or if is possible to get it in rpm format.
So, anyone knows wich mysql library I need? If someone knows how to install Zabbix on Red Hat could please tell me the requirements???
Thank you!!
Thank you!!
