1h & 2h ping graphs are blank
  • oliverm
    • May 2006
    • 155
    Hi chaps,
    I have a problem with all my icmp response graphs are blank if the period is set to 1h or 2h. However 4h+ and all the displays are fine. Checking the values for the same period shows there is data, and the last value is displayed correctly underneath the blank graph.
    It only appears to be ICMP RESPONSE that affected, but it' across all servers, and it doesnt matter whether its a custom graph, screen, or the graph thats generated from the graph link on the Latest Data screen.
    Running 1.4.
    Any ideas why this may be ?
    Olly
  • oliverm
    • May 2006
    • 155
    Any suggestions on this? The data is there but the graphs dont appear.
    Are there any caches on the server that may be the cause ?
    Olly
    • Calimero
      • Nov 2006
      • 481
      http://zabbix.com/forum/showthread.php?t=7842
      Maybe we're experiencing the same problem (but with different items definitions) ?
      • scott
        • May 2006
        • 17
        I experienced this issue. Changing my interval from 30sec to 60sec resolved the issue.
