Zabbix Agent Listen?
  • jonnjonzzn
    • Sep 2007
    • 18
    New to zabbix as we are evaluating for use in University environment with roughly 200 servers across Netware, Windows, HP-UX, Solaris, SUSE, RedHat.
    I am trying to understand the agent. Is it possible to collect performance data without the agent using a listening port? It seems that the two following directives in the zabbix_agentd.conf file would tell the agent to poll the server for what items to get and when. But when I set the listening port to only listen on localhost I lose monitoring via zabbix interface. Where am I misunderstanding this? Have tested only a linux client/host thus far.
    DisableActive=0
    RefreshActiveChecks=120
    Does this have something to do with the difference between item type zabbix agent vs. zabbix agent (active)? I have tried both ways without success.
    Basically, we would prefer the agents not to need an open port listening.
  • Niels
    • May 2007
    • 239
    This is what "active agent" is for. Make sure the server has port 10051 open and the the Hostname in the agentd conf is the same as in your host configuration.
