Configuration for Performance
  • ahanson
    • Sep 2007
    • 15
    I have a 1.4.1 installation of Zabbix up and running. It runs alright, but it doesn't poll as quickly as I want it to. I have 86 hosts actively monitored with about 76 items on each. That's just an average, some have more some have less. There are quite a few things I poll every 30 seconds, but the system seems to not poll but once every 5 minutes or so. This I got from the "Last 500 Values" screen.
    The zabbix server, apache, and mysql are all running on one machine. It's a dual-xeon 3.06GHz w/ 2GB of RAM machine.
    My question is this: in the zabbix server configuration, should I be starting more instances of pollers or something to make sure that as close as possible, every 30 seconds a value is taken? All of my checks are divided between the zabbix agent and snmpv1 (with a few simple check pings).
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    ZABBIX 1.4.x performance secrets:
    - use ZABBIX agent active checks whenever possible
    - tune ZABBIX database to use most of your memory resources, don't use default settings
    - tune number of pollers and trappers
    The 76 items per each host means 6536 parameters for monitoring, or 220 checks per second on average if 30 sec refresh rate is used. I am sure your system is capable of doing at least twice more.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • ahanson
      • Sep 2007
      • 15
      With only the 2GB of RAM, I'm going to see about throwing more in, just because it's easy to do and there's no reason not to.
      That being said, I have changed the amount of pollers to 30, and MySQL InnoDB Buffer Pool Size is set to consume 1GB of RAM, as this machine isn't dedicated to MySQL. I expect the 50% ratio to continue with the additional RAM. Everything else in MySQL is kept as a default. Should I also be tweaking any other InnoDB settings?
      • ahanson
        • Sep 2007
        • 15
        In regard to the active checking, I did this for a bit with log file monitoring, but any zabbix agent check can be an active check? Does this require any changes to the client's zabbix configuration file, or do I just change it on the server?
        Thanks again for all of your help on this.
        • bbrendon
          • Sep 2005
          • 873
          I'll chime in real quick.
          Not anything can be an active check. Agent items can be active. Simple, internal, etc can not. Yes, you have to put a hostname and server in the agent configuration file. I think that should be it.
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • fmtaylor2
            • May 2006
            • 66
            Performance FYI
            These are stats from my query engine (zabbix_server). I replicate this database to another (identical) server to run the web fronend (circular replication). It is a 4 processor dual core box with 16GB of RAM, and raid 10 on the database drives. If I knew how to tune it better I would.....
            Number of hosts (monitored/not monitored/templates/deleted) 238(195/31/12/0)
            Number of items (monitored/disabled/not supported)[trapper] 25353(14057/5936/5360)[1]
            Number of triggers (enabled/disabled)[true/unknown/false] 13991(7312/6679)[40/61/7211]
            top - 08:50:38 up 43 days, 22:05, 2 users, load average: 7.03, 7.08, 8.10
            Tasks: 178 total, 3 running, 175 sleeping, 0 stopped, 0 zombie
            Cpu(s): 80.5%us, 3.7%sy, 0.8%ni, 14.6%id, 0.1%wa, 0.0%hi, 0.2%si, 0.0%st
            Mem: 16507116k total, 16467736k used, 39380k free, 172624k buffers
            Swap: 2031608k total, 176k used, 2031432k free, 9619044k cached
            PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
            30359 mysql 15 0 6052m 5.4g 4740 S 661 34.2 340838:26 mysqld
            [root@boris ~]# ./tuning-primer.sh
            -- MYSQL PERFORMANCE TUNING PRIMER --
            - By: Matthew Montgomery -
            MySQL Version 5.0.22-log x86_64
            Uptime = 36 days 17 hrs 40 min 19 sec
            Avg. qps = 863
            Total Questions = 2741256566
            Threads Connected = 27
            Server has been running for over 48hrs.
            It should be safe to follow these recommendations
            To find out more information on how each of these
            runtime variables effects performance visit:
            http://dev.mysql.com/doc/refman/5.0/...variables.html
            SLOW QUERIES
            Current long_query_time = 10 sec.
            You have 1014900 out of 2741256742 that take longer than 10 sec. to complete
            The slow query log is NOT enabled.
            Your long_query_time may be too high, I typically set this under 5 sec.
            WORKER THREADS
            Current thread_cache_size = 32
            Current threads_cached = 6
            Current threads_per_sec = 0
            Historic threads_per_sec = 0
            Your thread_cache_size is fine
            MAX CONNECTIONS
            Current max_connections = 100
            Current threads_connected = 27
            Historic max_used_connections = 38
            The number of used connections is 38% of the configured maximum.
            Your max_connections variable seems to be fine.
            MEMORY USAGE
            Max Memory Ever Allocated : 7 G
            Configured Max Per-thread Buffers : 6 G
            Configured Max Global Buffers : 5 G
            Configured Max Memory Limit : 11 G
            Total System Memory : 17 G
            Max memory limit seem to be within acceptable norms
            KEY BUFFER
            Current MyISAM index space = 65 K
            Current key_buffer_size = 7 M
            Key cache miss rate is 1 : 0
            Key buffer fill ratio = 2.00 %
            Your key_buffer_size seems to be too high.
            Perhaps you can use these resources elsewhere
            QUERY CACHE
            Query cache is enabled
            Current query_cache_size = 1.00 G
            Current query_cache_used = 622 M
            Current query_cach_limit = 1 M
            Current Query cache fill ratio = 60.80 %
            MySQL won't cache query results that are larger than query_cache_limit in size
            SORT OPERATIONS
            Current sort_buffer_size = 64 M
            Current record/read_rnd_buffer_size = 2 M
            Sort buffer seems to be fine
            JOINS
            Current join_buffer_size = 132.00 K
            You have had 1 queries where a join could not use an index properly
            You should enable "log-queries-not-using-indexes"
            Then look for non indexed joins in the slow query log.
            If you are unable to optimize your queries you may want to increase your
            join_buffer_size to accommodate larger joins in one pass.
            Note! This script will still suggest raising the join_buffer_size when
            ANY joins not using indexes are found.
            OPEN FILES LIMIT
            Current open_files_limit = 2510 files
            The open_files_limit should typically be set to at least 2x-3x
            that of table_cache if you have heavy MyISAM usage.
            Your open_files_limit value seems to be fine
            TABLE CACHE
            Current table_cache value = 1200 tables
            You have a total of 83 tables
            You have 273 open tables.
            The table_cache value seems to be fine
            TEMP TABLES
            Current max_heap_table_size = 3.99 G
            Current tmp_table_size = 1.00 G
            Of 597440787 temp tables, 49% were created on disk
            Perhaps you should increase your tmp_table_size and/or max_heap_table_size
            to reduce the number of disk-based temporary tables
            Note! BLOB and TEXT columns are not allow in memory tables.
            If you are using these columns raising these values might not impact your
            ratio of on disk temp tables.
            TABLE SCANS
            Current read_buffer_size = 128 K
            Current table scan ratio = 82 : 1
            read_buffer_size seems to be fine
            TABLE LOCKING
            Current Lock Wait ratio = 1 : 133704927
            Your table locking seems to be fine
            • ahanson
              • Sep 2007
              • 15
              So when I upped the Poller count to 35, I'm now getting data just about every 30 seconds. For the first time I can see graphs all the way down to 1hr. I just migrated over all my zabbix agents checks to active checks, which is by far the bulk of my checking. Can't tell you how much easier this makes my life, and how much more I appreciate Zabbix!
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Be prepared to downgrade your quad CPUs and gigs of memory after upgrade to 1.6...
                Alexei Vladishev
                My Twitter
                • ahanson
                  • Sep 2007
                  • 15
                  Performance increased that much?? We are looking at doubling our infrastructure withing the next 6 months, so maybe I won't be, but that's certainly nice to know.
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    The development is not finished yet, so I have no exact numbers. I would expect ZABBIX 1.6 to be at least twice as fast comparing to 1.4.x.
                    Alexei Vladishev
                    My Twitter
