Zabbix Agent on Solaris 10 (Sparc)
  • Kai Ehlig
    • Aug 2007
    Hello
    Can somebody tell me how to install the Zabbix Agent on Solaris 10 (Sparc)
    Is there a compiled agent?
    A quick guide how to install?
    Is there a Fiewall on Solaris which i have to configure?
    On Linux i have to change the Port-Config
    THX
  • art
    • Oct 2006
    • 12
    You have to compile everything yourself from the source. Did it about a year ago for 1.1.x - as far as I remember it was a bit tricky but not too difficult. I haven't tried standard Solaris compiler - used gcc instead.
    • NOB
      • Mar 2007
      • 469
      Hi
      I created a Solaris package on Solaris 8 with gcc to install
      under /, i.e. /sbin/zabbix_agentd, /etc/zabbix/zabbix_agentd.conf
      But I didn't have time to test it on other Solaris versions, yet.
      Will try it on Solaris 9 and 10 (zone).
      Compilation with gcc was no problem. No tricks involved.
      HTH,
      Norbert.
