Cant't get UserParameter working
  • mindas
    • Oct 2007
    • 19
    Just installed Zabbix server and client, and feel very impressed about the quality and features (did use Nagios before, don't think will ever be looking back). However, I can't get UserParameter working. Basically, when I add configuration item and make it active, it switches to "Not supported" after a few seconds.
    This is my setup:
    1) Zabbix server version: 1.4.1 (out-of-the box Ubuntu Gutsy installation)
    2) Zabbix agentd is installed on Win2000 machine as a service (same version as of the server).
    3) Agentd path to executable (copy-paste from Windows service properties):
    "E:\zabbix\zabbix_agentd.exe" --config "e:\zabbix\zabbix_agentd.conf"
    4) Excerpt from e:\zabbix\zabbix_agentd.conf:
    UserParameter=testecho,java -version
    UserParameter=vyre.heap,e:\zabbix\heapused.bat
    5) Testing the agentd from the client machine (everything seems to be OK)
    E:\zabbix>zabbix_agentd -c e:\zabbix\zabbix_agentd.conf -t testecho
    testecho [t|java version "1.5.0_06"
    Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
    Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode)]
    E:\zabbix>zabbix_agentd -c e:\zabbix\zabbix_agentd.conf -t vyre.heap
    vyre.heap [t|26057688]
    6) But the vyre.heap task cannot be executed from the server. Server log level is set to 4 (debug), and the output is
    1016:20071004:153705 Parameter [vyre.heap] is not supported by agent on host [vyre-test1] Old status [0]
    Agentd log level is 4, and relevant output is
    2044:20071004:153755 Processing request.
    2044:20071004:153755 In check_security()
    2044:20071004:153755 Requested [vyre.heap]
    2044:20071004:153755 Before
    2044:20071004:153755 Sending back [ZBX_NOTSUPPORTED]
    3008:20071004:153756 Call to PdhCollectQueryData() failed: No data to return.
    Another UserParam (testecho) works just fine. I tried increasing timeouts, both in server and client as the heap checking is done via JMX takes a few seconds to finish but it didn't help.
    Does anybody know any other ways of tracing the problem? Any advice is much appreciated. Thanks in advance.
    Regards,
    Mindaugas
  • oliverm
    • May 2006
    • 155
    Make sure the HOSTNAME in the HOSTS entry in Zabbix for the server being monitored is the same as the name given to the server in the zabbix_agentd.conf file.
    This doesnt have to be a valid name at all, and can included spaces (we use "clientname - servername").
    We have had problems on windows clients with spaces in the script path in the userparams entry of the .conf file. Try putting this in a fodler with no spaces or using the 8.3 names (ie c:\progra~1\zabbix~1\ etc)
    Olly
    • mindas
      • Oct 2007
      • 19
      Hi Oliver and thanks for your reply.
      I've checked the hostname and it seems to be OK.
      My point is - if I have two UserParameters defined and one is working while another doesn't - it might be something wrong with the one of the UserParameters, isn't it? However, if I test them from the client (by doing zabbix_agentd -t key), both work correctly and report the data.
      The question is, what could be potentially wrong and where to look for an error? How can I know why my zabbix_agentd is Sending back [ZBX_NOTSUPPORTED]?
      Thanks again and appreciate your feedback.
      • mindas
        • Oct 2007
        • 19
        I was able to figure this out - it wasn't Zabbix problem, but mine (wrong paths ). Sorry for the unnecessary noice...
        • harishgupta111
          • Nov 2011
          • 41
          Hi
          HI mindas,
          I am getting the same error. I used ur example and tested with command zabbix_agentd.exe -c c:\zabbix_agentd.conf -t key.in.zabbix.frontend
          its showing correct results But still in zabbix its cmng not supported. My test.log file is placed in C:\temp\test.log and my config file is placed in c:\
          nd here is the userparameter:
          UnsafeUserParameters=1
          UserParameter=key.in.zabbix.frontend,C:\temp\test. bat
          and my log file is also placed in c:\temp\test.log. Now please tell me what may be the problem?
          Thanks in advance
          • lippoliv
            • Oct 2011
            • 15
            Hey there,
            if I run "zabbix_agent -t screen.num[mine]" (look http://www.zabbix.com/forum/showthread.php?t=23635) i get ZBX_NOTSUPPORTED...
            What can I do? Can Someone use this UserParameter for checking an active Screen Session?
            UserParameter=screen.num[*], screen -list | grep -c $1
