Hello all!
Use Zabbix 1.4.1, i want to check a timestamps of a folder with logs
UserParameter=timestamp,stat -t /home/zabbix/test/ | awk '{print $14}'
but status of item is Not Supported ((
Log:
8597:20071005:165014 Active parameter [timestamp] is not supported by agent on host [1313-3]
8597:20071005:165014 Type of received value [ZBX_NOTSUPPORTED] is not suitable for [timestamp@1313-3]
I uncomment the default parameter
UserParameter=system.test,who | wc -l
and test it - it works. But my UserParameter is not working
Any ideas will be very helpful for me, thanks!
Log:
