Alert when not getting data?
  • rolandsym
    • Jul 2007
    • 76
    I was wondering if anyone knows of a way to set up a trigger to check whether it's been too long since the last value sent. I'd like to know when a zabbix agent stops sending data. This would mainly be used for active check clients. I've tried the "Host status" native counter in zabbix but it's unpredictable. Some machines say it's not supported and while others it is but doesn't change. The client is 1.4.2 and these are all windows 2003 machines. Any direction or help would be appreciated.
    Rolandsym
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You may use function nodata().
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • rolandsym
      • Jul 2007
      • 76
      Thanks..
      Thanks for the quick response. It's helped alot. www.ofsometown.com:vm.memory.size[free].nodata(600) works great. Alot of additional functions in the manual ;-)
      Rolandsym
