Can I change from MyISAM to InnoDB
  • trentster
    • Oct 2007
    Hi I have been reading a lot of threads about using "InnoDB" for mysql, innitially I followed a howto for Centos 5 and it seems by default this is using MyISAM for mysql. I would like to change over to "InnoDB" and would like to know if this is possible with existing data in the database, and if advisable, is there anything steps that need to be followed to proceed with this change?
    Thanks In Advance
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It depends on size of you database, normally you can:
    1. mysqldump database structure and data to a file
    2. create database with type=innodb
    3. load everything into the new database from the file
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Niels
      • May 2007
      • 239
      Or you can first try to change a couple of tables with something like
      ALTER TABLE tablename ENGINE=InnoDB
      A backup would probably be good...
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Hmm, interesting how MySQL handles transactions and memory structures when one table is MyISAM and other InnoDB... I would switch the whole database to InnoDB to avoid possible problems (if there are any of course).
        Alexei Vladishev
        My Twitter
        • 0siris
          • Nov 2010
          • 76
          I know I'm kicking an ancient topic, but I got to this topic using the search, perhaps someone else can use my answer
          I used the following on our Linux server to convert a mysqldump file into innodb:
          sed 's/ENGINE=MyISAM/ENGINE=InnoDB/g' mysqldump > mysqldump_innodb
